K24a2 map needed
atili
K24a2 map needed
Post by atili »
tune or base will help. Mods: Skunk2 Stage 3 Tuner cams, supertech 92lb valve springs and retainers, 3in PLM ram horn headers, RBC manifold, stock rsx injectors,Full 3in exhaust, and a 70MM k tuned TB, and 3in CAI running base model rsx trans, basically running a head package, lots of thanks in advances all i need to get it going!
atili
Re: K24a2 map needed
Post by atili »
forgot to add that its also running a type S oil pump making, thanks.
CalibratEd
Post by CalibratEd »
I suggest you start with a stock tsx calibration and make adjustemnts to get the car drivable.
-Ed
Instagram: calibrated.tuning
atili
Post by atili »
I would but unfortunately I have no clue what I’m doing and want it to be drivable to my tuner
You should discuss this with your tuner, and they should be able to assist you with this.
CalibratEd
Like Spunkster mentioned, you should reach out to your tuner for a base calibration that can get you to the dyno.
-Ed
atili
Post by atili »
I would but they’re charging me an extra 100$ for a base tune to get me there and that’s not including the tune
CalibratEd
atili wrote: Fri May 30, 2025 1:04 pm I would but they’re charging me an extra 100$ for a base tune to get me there and that’s not including the tune
I’m not surprised. Did you try the stick tsx file like I mentioned prior? Post the file and a log. I can take a look at it and help you get it running well enough for you to make it to the dyno.
-Ed
