Base map d16y8 turbo 850cc injectors
Nusmi
Post by Nusmi »
hi im looking for someone that can send me a base map for a d16y8. im getting a tune in few weeks but i need something temporary that will be a little rich so i can make sure this thing is building boost, and something that has some safe timing so i can break it in thanks
d16y8 with SF rods , carillo pistons
stock head and pulley cam skunk2
850cc injectors
3" exhaust
38mm wastegate
skunk2 manifold
T3 PSR 3067 turbo
Nusmi
Re: Base map d16y8 turbo 850cc injectors
Post by Nusmi »
No one ?
CalibratEd
Post by CalibratEd »
Have you tried reaching out to your tuner for a base map?
-Ed
Instagram: calibrated.tuning
Nusmi
Post by Nusmi »
I don't have a tuner
CalibratEd
Gotcha. I assumed you did since you stated “ im getting a tune in few weeks ”.
-Ed
Nusmi
Post by Nusmi »
I meant that I would find one when it was ready and the car could be taken out of the garage.
For now I can't go out of the garage, as soon as I touch the throttle, stalls
That's why I need a minimum map so that it doesn't stall and can go at least 50m outside.
CalibratEd
Post the calibration you are running and a datalog. I can take a look at it. Have you applied the proper injector data? Do you have a wideband installed?
-Ed
Nusmi
Post by Nusmi »
Calibration, is stock " d16 p28 " from S-Manager i only put 850cc in injectors paramètres
CalibratEd
Gotcha. Do you know what brand the injectors are? Are you running a wideband?
- Ed
Nusmi
Post by Nusmi »
hi , yes Aem x series wideband and injectors specifications :
EV14 Injector, 12 Ohm, 870cc, C25, Jetronic (EV1), O-O 34 mm, Short, Long Spray End (EV14-870, Bosch 0280158209)
Maximum flow approx 870cc @ 3 bar
Short type injector (O-ring distance is 34 mm), long spray tip
Compatible with E85/RE85 and gasoline
14 mm O-rings, compatible with ethanol and gasoline
Jetronic (EV1)-type connector
High resistance
6 hole spay tip
Conical type spray
CalibratEd
Post the calibration you a running with a datalog. I can take a look at it.
-Ed
Nusmi
Post by Nusmi »
CalibratEd wrote: Wed Jun 11, 2025 8:03 am Post the calibration you a running with a datalog. I can take a look at it.
-Ed
here
