S300 E-Tuners?
BoiseIntegra
S300 E-Tuners?
Any E-Tuners available to tune my integra? I put a UEL header from 1320 on it and just want to get it tuned properly especially after I put some new sparks in it and gapped to .51.
- CalibratEd
- Contact:
Re: S300 E-Tuners?
Have you tried running one of the Hondata calibrations? Does the car have a wideband installed?
- Ed
- Ed
Instagram: calibrated.tuning
BoiseIntegra
Re: S300 E-Tuners?
I have not tried running one of the auto tuners in the hondata software. It does have a wideband, but right now I installed the header and the AFR is stuck at 14.7.
- CalibratEd
- Contact:
Re: S300 E-Tuners?
At idle or during part throttle and WOT?BoiseIntegra wrote: Tue May 27, 2025 7:18 pm I have not tried running one of the auto tuners in the hondata software. It does have a wideband, but right now I installed the header and the AFR is stuck at 14.7.
-Ed
BoiseIntegra
Re: S300 E-Tuners?
Both idle and WOT/part throttle. I bought a new o2 sensor using the OE part number on the old o2s. I will update once i've replaced the sensor. This 14.7 thing has only started to happen when I changed the header. I believe I may have a leak somewhere in the exhaust to the cat and all the way back.CalibratEd wrote: Wed May 28, 2025 2:27 pmAt idle or during part throttle and WOT?BoiseIntegra wrote: Tue May 27, 2025 7:18 pm I have not tried running one of the auto tuners in the hondata software. It does have a wideband, but right now I installed the header and the AFR is stuck at 14.7.
-Ed
BoiseIntegra
Re: S300 E-Tuners?
AFR is fixed. Now I just need it tuned proper. The car has some seriously intense internals. Compression is 13.0:1 with type R cams. Supertech dual titanium valve springs 70mm TB S2 intake mani with K series injectors and AEM fuel rail. 1320 UEL header.CalibratEd wrote: Wed May 28, 2025 2:27 pmAt idle or during part throttle and WOT?BoiseIntegra wrote: Tue May 27, 2025 7:18 pm I have not tried running one of the auto tuners in the hondata software. It does have a wideband, but right now I installed the header and the AFR is stuck at 14.7.
-Ed
- CalibratEd
- Contact:
Re: S300 E-Tuners?
Glad to hear. What is the AFR now at idle and part throttle?BoiseIntegra wrote: Thu Jun 05, 2025 7:17 pmAFR is fixed. Now I just need it tuned proper. The car has some seriously intense internals. Compression is 13.0:1 with type R cams. Supertech dual titanium valve springs 70mm TB S2 intake mani with K series injectors and AEM fuel rail. 1320 UEL header.CalibratEd wrote: Wed May 28, 2025 2:27 pmAt idle or during part throttle and WOT?BoiseIntegra wrote: Tue May 27, 2025 7:18 pm I have not tried running one of the auto tuners in the hondata software. It does have a wideband, but right now I installed the header and the AFR is stuck at 14.7.
-Ed
-Ed
