RevL issue at 3400 Rmp
Nusmi
Post by Nusmi »
Hi, I have a cut-off REVL at around 3400 rpm.. even though no limiter is set in the calibration. I don't understand where it comes from. Does anyone have an idea?
Re: RevL issue at 3400 Rmp
If you look at error codes you have errors for fuel injectors and atmospheric pressure. These may need to be disabled if the ECU does not have that circuitry.
Nusmi
Post by Nusmi »
Hello Spunkster,
The injctors are new and the map sensor too (4 bar Hondata) I checked all the wiring several times and there are no connection errors I don't know why the ECU detects these errors and and it also finds an wrong value of iat &ect temp (stock sensors)
Nusmi
Post by Nusmi »
Isn't that what starts the revL?
What is the part number of your ECU?
Nusmi
Post by Nusmi »
Hi,this one
That ECU does not have the circuitry for those, and the errors must be disabled in the Misc. section calibration.
Nusmi
Post by Nusmi »
Thank's Spunkster, but could this error be the cause of the revL at 3400 rpm?
most likely
civic EK sir
Post by civic EK sir »
Hi, i notice that the timing is very low in most of the datalog 0~6 deg?
19 @ 3psi is this Turbo.
Can you share the setup
Nusmi
Post by Nusmi »
She is here
Nusmi
Post by Nusmi »
Spunkster wrote: Mon Jun 09, 2025 9:03 am That ECU does not have the circuitry for those, and the errors must be disabled in the Misc. section calibration.
Hi Spunkster, if i disable map sensor in the Misk the idle fall and rmp dead
There is no way to disable MAP sensor form the Misc section. I do not understand what you mean.
Nusmi
Post by Nusmi »
Spunkster wrote: Mon Jun 16, 2025 11:18 am There is no way to disable MAP sensor form the Misc section. I do not understand what you mean.
Did I make a mistake or misunderstand?
That is not disabling the MAP sensor.
