In the sensor options, I can only find the K.Count values for cylinders 1 to 4 and the total count. I would like to know if there's a way to view misfire data, or if K.Count includes misfire data? Thank you.
Model:2022 Civic 1.5T
ECU:6KA-H03
FlashPro Manager:4.4.7
Misfire data on a 2022+ civic 1.5T
Re: Misfire data on a 2022+ civic 1.5T
Misfires are not a datalogged parameter.
AllenZhangFE3
Thank you very much for your reply.
Since I have rebuilt my engine and upgraded the fuel system, I occasionally notice fluctuations in the air-fuel ratio at idle — sometimes dropping below 13 and rising above 16. These fluctuations don't last long, but I would like to understand what might be causing them.
Misfires could be a possible reason. However, the ECU hasn't reported any errors, so perhaps the misfire data isn't significant enough to be flagged?
Thank you.
Thank you.
You should be able to hear misfires.
