Stock k24a
Csx-si
Stock k24a
Post by Csx-si »
I just finished a completely stock k24a swap in my 2011 csx using a 08 si ecu.
I have flash pro and looked for a k24 base map and learned that thats not a thing when using a civic si ecu.
Whrn buying the flashpro I fully expected that I would be able to put a stock k24 map on the ecu and be good till I can save up enough $$ to get properly tuned as this swap has broke the bank so to speak.
I went for a drive on the stock ecu and almost immediately got a check engine light for p0172-system too rich bank 1.
So, is there anyone that could help a guy out with a factory tune or whatever for this motor so i dont hurt it?
Its my daily and means of getting to work. And at this point, i am up shit creek without a boat or paddle as I can not afford to pay for tuning yet.
Cheers.
CalibratEd
Re: Stock k24a
Post by CalibratEd »
Post the calibration you are running with a datalog. I can take a look at it and help make it run safe.
-Ed
Instagram: calibrated.tuning
