Torque table question for DE5
DomGSR-T
Post by DomGSR-T »
Hi,
Using the 93 octane map and setting the 2nd gear torque table for sport+ mode to lower value (250 max at 100% tps) I get 26-27 BP CMD... and massive spin... Do I need to change something else to get this to work? The boost by gear method works btw...
jeffx
Re: Torque table question for DE5
Post by jeffx »
Sorry if it seems like a dumb question but are you sure you were in Sport+ mode? I see your other 2 2nd gear tables (comfort and sport mode) are requesting 600nm in 2nd gear.
DomGSR-T
Post by DomGSR-T »
Yes :) I have noticed this issue for a while now and created that map just to show the problem I have...
jeffx
Post by jeffx »
what happens if you set all 3 of the 2nd-gear throttle maps to what you've set for the 2nd gear R? If it works as expected, then there could be a bug in FPM or something else.
because as it is, you can see from this logs (and this screenshot) that the ECU is making a Torque Request of 100% which indicates it's reading a value of 600Nm from a throttle map (obviously not the one you've put in the calibration) when you go WOT .
DomGSR-T
Post by DomGSR-T »
Ok I found the problem!
2 tables are mixed up... I tested all the gears with 250 lowered torque values in comfort mode and the boost was low/limited on all gears...
Then tried the same thing with 250 lowered torque values in sport mode... did not work... I was at full boost... I switch to sport+ then boost was low/limited on all gears...
Then tried the same thing with 250 lowered torque values in sport+ mode... did not work... I was at full boost... I switch to sport then boost was low/limited on all gears...
So sport and sport+ torque tables are mixed up :) I think this a an easy fix...I don't know if it's only for the DE5 though...
jeffx
Post by jeffx »
yeah it seems like that's something that needs to be corrected in FlashPro Manager. Better yet, since this is a calibration specific to the DE5, the tables should probably be relabled to match the modes that are displayed for the DE5 vs FL5/FK8 in order to avoid any such confusion.
I can switch the Sport and Sport+.
jeffx
Post by jeffx »
Hondata wrote: Mon Aug 04, 2025 10:08 am I can switch the Sport and Sport+.
If it's possible to simply relabel the existing tables in FlashPro Manager so they're connected to the correct mode that should be sufficient without requiring reflashing, is that correct?
