closed loop question
panoramix3519
When i work in closed loop and the ecu is trimming the maps for example 4%, when i go full throtlle so i am in WOT so i am in open loop, the trimming from closed loop the 4% is still triming from the maps or the trimming is working only when i am in closed loop and when i go to wot is the maps working without triming?
MondeCruel
Re: closed loop question
Yes you have a value in closed loop parameters it is the maximum MAP for closed loop, above this MAP it is open loop
panoramix3519
yes but my question is if the the trimming from fuel bank in closed loop is trimming still when i am in wot (open loop) or not
yes this is normal
panoramix3519
so when i have long term fuel bank for example -3% and i am in wot the fuel maps is still trimming -3% at wot (open loop). Is that correct or at wot is the fuel maps without trimming?
It will use the fuel trim in open loop for safety.
