CANFLEX LIGHT BLINKING RED
fl5.manny
Post by fl5.manny »
So I installed the canflex on my fl5 and I flashed the car with the correct tune and then started it. I get a cel and the the can box is blinking red indicating a wiring issue. I double checked every connection, re-flashed the tune but its still blinking red. I think I may have a faulty harness but I don't have time to send it back. I also think that the pins may not be seated all the way which I will check today. Any suggestions??
Re: CANFLEX LIGHT BLINKING RED
Take pictures of the harness and connector plugs and post them here
fl5.manny
Post by fl5.manny »
will do, when I get home.
fl5.manny
Post by fl5.manny »
Pics of the harness
post pictures of the other harnesses that plug into the E/B/CANB box and where it connects to the Flex fuel sensor.
fl5.manny
Post by fl5.manny »
Pics added
I need to see the wire colors on the both ends of the sensor cable and on the cable coming from the adapter
fl5.manny
Post by fl5.manny »
All of the cables are in the correct orientation, I think I just have a faulty harness. But I’ll send them anyways.
fl5.manny
Post by fl5.manny »
Not sure if this is what you want to see.
fl5.manny
Post by fl5.manny »
*update*
User error, I ordered the wrong version…..
