2017+-2022 CRV 1.5T/CVT tuning help
scofield
Post by scofield »
I have a 2022 CR-V 1.5T CVT equipped with a race header and the stock cat-back exhaust. I am planning further upgrades and have a few questions regarding the calibration:
Q1: I plan to install the aFe Takeda Momentum Cold Air Intake (3.5"). Does the Hondata base map include a specific selection for this intake? If there is no pre-set option, how should I proceed with the calibration?
Q2: Following up on Q1, I also want to upgrade to the PRL High-Volume MAF Housing (75mm ID). I understand this requires scaling the MAF sensor. Is there a built-in "drop-down" option for this hardware in the software, or where specifically should I go to input the new hardware parameters?
Q3: If I upgrade to the PRL Turbocharger Inlet Pipe, what specific adjustments or compensations should be made in the tune to account for the increased airflow into the turbo?
thanks you
Re: 2017+-2022 CRV 1.5T/CVT tuning help
There are no options for this pre-tuned with those parts. It will need to be tuned on the dyno for these.
scofield
Post by scofield »
have any default vaule suggest for this MAF change ?
Could you please guide me on which specific tab in FlashPro Manager I should use to input these values? Is it under 'Calibration > Sensors > MAF Scaling', and are there any other compensation tables (e.g., IAT or AFM) I should adjust to ensure the 75mm MAF housing functions correctly?
I don't' have values to give you. This will need to be tuned by someone familiar with tuning these types of vehicles with these parts.
