How to tune the MAF on an FL5
qinyuan.zou
Post by qinyuan.zou »
When I tune the MAF on the FL5, should I refer to the short-term fuel trim (STFT) or the total fuel trim value?
Re: How to tune the MAF on an FL5
You will want to look at the AF and the short term trim.
qinyuan.zou
Spunkster wrote: Mon Mar 16, 2026 9:05 am You will want to look at the AF and the short term trim.
Sorry, I didn't catch that. Did you mean looking at the difference between AF and AFCMD?Could you explain it in more detail?
You will need to look at both and make necessary adjustments to the areas that need more or less fuel.
qinyuan.zou
Spunkster wrote: Tue Mar 17, 2026 11:55 am You will need to look at both and make necessary adjustments to the areas that need more or less fuel.
Thanks, I'll give it a try.
soloth
Post by soloth »
qinyuan.zou wrote: Mon Mar 16, 2026 8:23 am When I tune the MAF on the FL5, should I refer to the short-term fuel trim (STFT Geometry Dash) or the total fuel trim value?
You should use Total Fuel Trim (STFT + LTFT) as your main reference when adjusting the MAF curve.
qinyuan.zou
soloth wrote: Wed Mar 18, 2026 11:53 pm
I tried, but from the logs I found that the short-term fuel trim (STFT) for many ranges is -0.5%, long-term fuel trim (LTFT) is 0, and the total fuel trim is -1.5%. So I don’t know whether to base it on STFT or total fuel trim
jeffx
Post by jeffx »
qinyuan.zou wrote: Thu Mar 19, 2026 12:48 am
it sounds like your trims are already dialed in pretty well.
