STFT Active - in Open Loop
wal
Post by wal »
Hi, how are you?
This is the first time I've seen this. I can't figure it out because I'm still getting corrections in WOT.
The car is a K20/K24 build with 12.5 RC cams.
I made several maps for different friends' cars, with different configurations, but this is happening with mine.
I've attached the map and log.
There's a part of the datalog where the IAT disconnects, which is why I'm getting a DTC.
I would appreciate it if someone could see where I'm going wrong.
wal
Re: STFT Active - in Open Loop
Post by wal »
Does anyone have any idea what might be happening?
Most likely there is an intermittent wiring issue that is causing this.
wal
Post by wal »
It's the original wiring, it would be strange but I'll check.
Another strange thing that sometimes happens is that when I connect it, the Hondata's lights keep blinking until I disconnect it from the car and the computer. When I reconnect it, it works correctly.
Is it just the O2 sensor wiring or could it be anywhere?
wal
Post by wal »
Another thing that sometimes happens is that while the car is idling and I connect the Hondata, it revs slightly and then returns to normal.
Could this be an internal problem with the device?
What is the FlashPro serial number?
wal
Post by wal »
I'm not home right now, but I'll be back on Thursday and I'll share the information.
I don't know if this is relevant as additional information, but this car had a K20 engine, then a complete K24Z1, and now a K20/K24. I didn't have these problems before.
The only thing I remember modifying (without cutting wires) is replacing the MAF sensor with an IAT sensor.
wal
Post by wal »
The serial number is FP-SI-US-15091
Your software is out of date. Please download the most recent version at: https://hondata.com/software?route=info ... nformation
wal
Post by wal »
I tried checking for updates, and it seems I have the latest version. However, I don't fully understand the versions mentioned in the message.
It seems I'm using the beta versions, but I don't remember selecting that.
I can try reinstalling everything from scratch, should that work?
Just download and install form the link I gave.
wal
Post by wal »
I tried it with everything updated and got the same result, so it seems to happen after engaging VTEC.
Attached log
I don't see any errors and short term fuel trim appears to be acting normally.
wal
Post by wal »
It shouldn't activate in wot, I don't understand why it doesn't stay in Open Loop, after engaging VTEC it switches to closed, I can't understand why it does that.
wal
Post by wal »
Spunkster wrote: Thu Apr 16, 2026 12:59 pm I don't see any errors and short term fuel trim appears to be acting normally.
Another thing I noticed, and I don't recall if I mentioned it before, is that at the VTEC point, it displays "Open - Cold" and then switches to "Closed Loop." From that point until the cutoff, it remains closed.
Could you take a look at the calibration?
I'm not sure what property is causing this, or if it could be a faulty O2 sensor heater.
