Alternate VSS input issue
fucatypr
Post by fucatypr »
I have entered the correct gearing for this car (BMW). It will display the speed from the alternate speed input but launch control will not disengages and I have no VTEC
Re: Alternate VSS input issue
What is the serial number that is on the K-Pro board inside the ECU?
How do you have the VSS Signal connected to the ECU?
fucatypr
Post by fucatypr »
56962 purchased from Humble Performance
I'm sending the signal through a Dakota Digital SGI-100BT
But how is it connected to the ECU?
fucatypr
Post by fucatypr »
Into the alternate VSS input
There is no reading of the VSS in the datalog you have posted.
fucatypr
Post by fucatypr »
It shows up under vss input for me
The datalog you have posted does not show any VSS activity. Datalog again and post the datalog and the calibration it was made with.
fucatypr
Post by fucatypr »
That's picture is from the datalog I posted. It says 0mph on vss but it shows up under vss input just like in the picture.
If there is no vss showing in the actual datalog and you are having issues with the VTEC and launch control, then the ECU is not seeing the vss signal.
fucatypr
Post by fucatypr »
Why is it showing up under vss input then?
It's not in the datalog you have posted.
fucatypr
Post by fucatypr »
Can you explain what this is?
fucatypr
Post by fucatypr »
Sorry, I tried to attach a picture. Can you explain why I can see a VSS input like in the picture I posted. The MPH is even correct
I cannot, as you are not getting a vss signal in the actual datalog, so the ECU cannot see this signal.
