what size inectors to replace fmu?
jdmferio93
Post by jdmferio93 »
I have a jackson racing supercharged b16 and trying to get rid of the fmu and fuel enrichment relay and was going to get a set of 440's but was told to go bigger just incase...so what do i get?
440's a map relocator and the s300 will be all you need. You can get the map relocator through Jackson Racing.
jdmferio93
i have the map relocator i am not using it because the box got fried but i guess that doesn't matter since i will be using hondata right?
You will have to remove all the Jackson Racing electronics. More details can be found at http://www.hondata.com/tech_jrscinstall.html
picnic_george
Post by picnic_george »
All the map relocator is, is a piece that mounts the map sensor so you can run a vacuum line for it. When you order it make sure it has a nipple on it for the vacuum line. Mine came without one so I had to make shift one in there.
jdmferio93
so i remove all of jacksons stuff except the map sensor spacer?
