Sloowwww recording with latest version
kenton
Post by kenton »
I only use this laptop for KManager, nothing else.
My average FPS in 1.2.1.5 was in the 20s and 30s
Now it's stuck right at 10-11fps
I tried to revert back to 1.2.1.5 by uninstalling .6 and reinstalling .5. I got a message I was using an old version so I deleted the version key in the registry. That eliminated that problem but when I went to upload a calibration it failed everytime.
I reinstalled .6 on the fly and I could upload a calibration.
How can I reinstall .5 and it work like it did before I upgraded to .6.
I want to eliminate Hondata software as a possible cause for slow FPS during datalogging
There are so many disclaimers and warnings in our lives that we get used to ignoring and circumventing them, and therefore can't recognise a genuine warning when we see it. Blame the lawyers.
Do you know the internal changes made between 1.2.1.5 and 1.2.1.6 and the full effect and ramifications of 'downgrading' on datalogging, your calibration, your ECU and your vehicle? If so, disable the warning message. Otherwise, read on.
The first step is to report the problem to us. Which in this case, is that you find the new version datalogs slower than the old version. Then I'll ask you to run through some steps:
- what is your laptop spec?
- close and reopen KManager, clear security, then upload to thr ECU again.
- check in the device manager what it says for the "Hondata K-Series ECU" under 'Properties', 'Details' then 'Hardware ID'.
- if possible, try another laptop for datalogging
kenton
Post by kenton »
Hondata wrote:There are so many disclaimers and warnings in our lives that we get used to ignoring and circumventing them, and therefore can't recognise a genuine warning when we see it. Blame the lawyers.
I'm sorry, I didn't realize the updates were so significant. For the record, I made a backup of all my calibrations and datalogs OUT of the KManager folder BEFORE I installed the upgrade. Any wise tuner would do that!
Laptop spec - Celeron 2.4GHz, 512MB RAM, minimal installation of Windows XP with nothing running in the background. I am a computer expert so I do not believe the problem lies in my laptop.
I don't feel like messing with it again until the morning, but thanks for your quick reply. I can't help but notice the sarcasm in your tone about the disclaimers. If I was smart enough to hack the registry to find KManager's version key, I think I can read the disclaimer.
MY ASSUMPTION WAS - because I started with 1.2.1.5 I could simply reinstall it and use my BACKED UP calibration files. KManager would say it was online and ignition was on, but would not upload. It would immediately error out. Upon reinstalling 1.2.1.6 this problem was solved.
I don't understand where I went wrong in:
- Uninstalling 1.2.1.6 (I uninstalled BOTH USB drivers and KMananger)
- Reboot laptop
- Install 1.2.1.5 again
- Reboot laptop
- Open KMananger, install USB drivers
- Reboot laptop
- Open KMananger, upload BACKED UP calibration
To me, that seemed like the logical step.
But in the morning I will be more than happy to supply you with the device ID shown and will follow any future steps you have for me.
I apologize again.
kenton
Post by kenton »
In addition, if there is a legitiment way to downgrade back to 1.2.1.5 please let me know.
Like I said, I have a folder with my 1.2.1.5 specific calibrations and datalogs that have not been touched by the 1.2.1.6 software.
You're missing the point of the last post. The warning message is there for a reason. You cannot downgrade versions.
kenton
Post by kenton »
Sorry for not having the information ready for you.
I understand then, I will not attempt to downgrade versions in the future.
Give me an hour or so and I can provide a datalog and the requested information.
Thank you for your continued support
Testing on two PCs here, with all windows apart from 'Sensors' closed, the new KManager version datalogs at the same speed as the old (old laptop 59 fps, new PC 55 fps) Try to clear security and re-upload, then re-test.
