takashi
Posts: 8 Joined: Thu May 18, 2006 11:09 pm
Post
by takashi » Mon Jun 19, 2006 8:10 pm
Any Calibration for B18C JRSC with 240cc orginal injecter? or Can I use B18C JRSC with RC 440cc injecter Calibration and just change Fuel Trim to 240cc?
Posts: 24143 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Tue Jun 20, 2006 9:42 am
You should not use stock injectors and boost...you will have major problems.
takashi
Post
by takashi » Tue Jun 20, 2006 8:24 pm
Rally? I Didn't Know About It. But If I Don't Use Boost、 Is That OK?
Post
by Spunkster » Wed Jun 21, 2006 9:17 am
Then why have a supercharger?
takashi
Post
by takashi » Mon Jun 26, 2006 12:03 pm
Spunkster, I have a question. Is JRSC engine make burn engine oil faster than normal engine? or maybe have problem my engine.
Post
by Spunkster » Mon Jun 26, 2006 1:00 pm
You should not burn oil because of a supercharger. It sounds like you have some kind of engine damage. This could be caused from running too lean.
NeriVtec
Posts: 6 Joined: Tue Mar 21, 2006 10:41 pm
Post
by NeriVtec » Tue Nov 07, 2006 9:35 pm
If it is a B18c1 with a JRSC at 6lbs with stock injectors, will this work??
Post
by Spunkster » Wed Nov 08, 2006 10:13 am
No, you should not use stock injectors as they will not flow enough fuel and you will not be able to add enough fuel and will run lean.
NeriVtec
Post
by NeriVtec » Wed Nov 08, 2006 6:17 pm
So there is no map that can be used until the injectors are put in?
ITR 1102
Posts: 144 Joined: Sun Sep 10, 2006 9:52 am
Post
by ITR 1102 » Wed Nov 08, 2006 9:29 pm
that is correct. what good would a map do you if your injectors will not work. even if you created a map with the stock injector size and have the duty cycle maxed out, you still wont flow enough fuel.
get the injectors like Spunkster said, then use the basemap supplied in the sticky portion of this forum found here.
http://www.hondata.net/forum/viewtopic.php?t=4397
