h22supercharger 550 injectors
rommelduran
Re: h22supercharger 550 injectors
Post by rommelduran »
hello, i'm trying to see if you have a s300 calibration for a h22 turbo with 750cc injectors !!! I would really be greatfull!!!!
ludechopper
Post by ludechopper »
has anyone modified this to work with a motorvations boost upgrade pulley or does anyone know what would need to be changed I want to get it close where I can drive it to have it tuned
turbo95lude
Post by turbo95lude »
How many lbs of boost is this calibration tuned to?
Thanks,
Gforce2rbolude
410@18psi
To about 10 psi with a Jacksonracing Supercharger. THis should not be used with a turbo.
quickaccord93
Post by quickaccord93 »
thanks for this calibration
you fix my idle problem :D but for your information, this calibration run very lean in boost
spec: h23a vtec, JRSC, 550 cc injector
deafy
Post by deafy »
How much boost are you running?
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
quickaccord93
7 psi
I dont have any control on boost level with the JRSC
