CTSC RSX TYPE S Datalog Need Help Please
jpslick
Post by jpslick »
Hey guys i have a datalog of my car and i could use a hand on tuning it a little better if someone would like to tackle it...
Running 02 RSX Type S Comptech Supercharged @ 5PSI Stage 1 STock Injectors
5000 RPM and up is pretty solid
but under 5000 RPM my A/F is garbage
infact so bad when i ease into boost it cuts me off completely and the car bogs down (maybe due to lean protection)?
Full throttle car runs fine but lightly accelerating (part throttle) into boost it cuts out and i have to let off the gas
If someone could take a look at my datalog and Map and adjust accordingly i would appreciate + i dont have enough experience to go messing with it....also im not sure if the car is safe to run?
02 CTSC RSX K Pro'd
You have changed the fuel tables, but only have altered the 0 degree cam table. The AF is not that bad under load, but I'd suggest starting afresh and making changes to all fuel tables.
The cut is problem from lean protection - increase the activation time from 250 ms.
