Push button install question
mikeedge
Post by mikeedge »
I am currently tuned on Hondata S200. I am looking into installing my push button so I can control my rev limit, launch control, and shift light.
I have read on the Hondata installation guide that once installed... the rpm points are initially set to the following...
Launch Limiter: 3000rpm
Cam Change point: 4800rpm
Shift limiter: 6000rpm
Shift light: 7800rpm
Now my question is... my vtec crossover is set right now to 4400rpms. Once I install this, is it going to switch it to 4800rpm? and am I going to have to reset it back to 4400rpm?
Thanks for any help.
If VTEC has been set in the ecu it cannot be adjusted via the interface box.
mikeedge
Post by mikeedge »
Okay, so I don't have to worry about my crossover going to 4,800rpm?
mikeedge
Post by mikeedge »
Okay, I plugged the push button in and set my launch control rpms to 2,500 statically. I turn my car on and press the clutch in and when I step on the gas pedal, the launch control doesnt work, my rpms just rocket.
Any ideas why?
Datalog and make sure that the ecu is seeing the clutch switch engaging and disengaging.
mikeedge
Post by mikeedge »
Lol, I found out that I need the clutch switch. I was under the impression that I only needed the clutch switch for Full throttle shift.
Where should I get the clutch switch from? I have access to pepboys, advance autoparts, etc.
What are they called exactly?
mikeedge
Post by mikeedge »
Okay, I went out to pepboys and bought a switch. Now my question is, How do I go about hooking it up to the Hondata?? It didn't come with any wires or anything.
mikeedge
Post by mikeedge »
Lol, I looked through that manual so many times. It just does not say how to hooke up the clutch switch to the hondata.
I am fully aware of where to put the clutch switch, but just not how to hook it to the hondata.
It plugs in on the interface box where it says "Clutch Switch"
mikeedge
Post by mikeedge »
Lol, I am aware of that. But I do not have any wires that plug into that. The clutch switch I bought came with just a clutch switch. Here are some pics of it...
Every s200 is shipped with the necessary cable to connect to the switch.
mikeedge
Post by mikeedge »
Hmm, well I bought this from a member off Team-Integra so that could explain why I do not have the cable. I did have th push button tho.
How could I acquire one of these cables?!
Ps. Thanks a lot for all your help! I appreciate it.
You can purchase a replacement through any Hondata dealer.
mikeedge
Post by mikeedge »
Okay, is it just the cable? or the clutch switch as well?
