Prelude Type SH
luder3082
Prelude Type SH
Post by luder3082 »
I'm intrested in your product and found that ATTS would be disable why is this?? Did HONDATA forget Us ATTS users ??
ATTS cannot be run when you convert to an OBD1 ecu. The only way to run a Hondata system is with an OBD1 ECU. This means you loose ATTS when you use a Hondata system.
luder3082
Post by luder3082 »
okay is there a way u can give me pin diagrams for obd I and obd II ..
sr73087
Post by sr73087 »
yes i would like to have them also
RyosukeFC3s
Post by RyosukeFC3s »
Spunkster wrote:ATTS cannot be run when you convert to an OBD1 ecu. The only way to run a Hondata system is with an OBD1 ECU. This means you loose ATTS when you use a Hondata system.
That sucks. I guess I should try to sell my ATTS. :?
