Is there a way to speed up antilag revs
B16T
Post by B16T »
im woundering if anyelse notices that the anti lag rev bounce is alittle slow compared to other anitlag program?
Can you describe what you want in a little more detail? What rpm do you have the launch limiter set to, and what rpm hystersis do you see?
B16T
Post by B16T »
my 2step limit is set about 7k and activation is at 6900 , It just seems the delay between bouonces is alitlle slow compared to other 2steps ive heard just woundering if thats the way the hondata is or something that i can change
We'll look at it.
B16T
Post by B16T »
It seems the the 2step limiter is slower then the engine revlimiter, Thanks
kaj
Post by kaj »
it sounds like he has an issue with how far the RPMs drop and how slow they drop/come back up. he's probably thinking of AEM and other 2-steps that crackle and pop and seem to be keeping the RPM at the desired level.
with hondata you get a "slower" rise and fall of the tach needle.
am i close?
B16T
Post by B16T »
You got it mann, Yea i love the hondata i was just checking if there was something i could do, or if thats the way it is, But i can turn the 2step up and screw around with the antilag settings, If you guys can look into getting a faster response us B16 guys with big turbos would likey
B_Rex
Post by B_Rex »
I was street tuning my car last night and I had my launch control set to 3500rpm but I noticed that the tach wasn't reaching that high and it was coming back up very slowing compared to other launch controls I have used and seen. So I started looking through the help section and came across this in the help section;
The stock and recommended setting is a Fuel only rev limiter. By selecting Fuel + Ignition, the ignition is also cut when the rev limit is activated.
Important Note: Since the ECU ignitor output is disabled when the ignition limiter is in effect and the stock tachometer is driven from the ignitor, the tachometer will not work when the ignition cut rev limiter is in operation.
So I think its actually faster than it appears. I built 6lbs of boost even at that low of rpm in 4 pops.
B16T
Post by B16T »
So what are you saying? just keep the fuel cut or fuel and ignition cut ?
B16T
Post by B16T »
See im not getting any pops, what do you have your ignition retard and fuel set at? and are you runnin the fuel cut or fuel and igniotion cut?
Shmaa
Post by Shmaa »
I would like to know as well
