Alpha-N and closed-loop
CivicVTi
Post by CivicVTi »
I have a question about max closed loop threshold when using Alpha-N. Say I set it at 70KPa, does the ECU disable closed loop when the calculated TPS exceeds the corresponding MAP value?
When using TPS based lookup the closed loop threshold is the calulated MAP from TPS, not the actual MAP.
CivicVTi
Post by CivicVTi »
Yes, this is what I was talking about. Thanks Hondata.
So, considering the large airflow for relatively low throttle openings when using ITBs, I guess a good value for max closed loop threshold is around 20% throttle. What do you suggest?
Probably between 10 % and 20%. It will increase with rpm. Datalog and check TPS at cruise rpm and throttle. Make sure you tune the fuel tables to a reasonable AF ratio so that if it does switch into open loop you're not going to get a drastic change in AF ratio.
CivicVTi
Post by CivicVTi »
OK, thanks once again.
EGHATCH
Post by EGHATCH »
Hi,
what ITBs are you using? i'm having a hard time tuning itbs. whenever i set MAP to alpha-n, the columns (TPS %) shows -9, -8, -7, up to 0%, when i believe it should be 0% to 100%.
you wont learn until you actually do it.
CivicVTi
Post by CivicVTi »
Right click on the load values and edit them. You can use whatever values you want. From my experience you need high resolution for low throttle openings (0%, 2%, 5%, 8%, 10%) and low resolution for high throttle openings (50%, 70%, 100%).
TUning ITBs is a little tricky. I suggest a dynapack and careful tuning. Be careful not to overadvance the timing as the timing map has a completely different pattern than the MAP based one. Keep in mind that especially at low revs, you have almost full power with throttle as low as 10% and so you need to decrease timing a lot, almost to the full load value.
It tool me 3 hours to tune a Toda ITBs equipped K20a2. The outcome is very good and driveability is almost like stock.
EGHATCH
Post by EGHATCH »
i see what you mean. i have to manually edit all the column values? it will take me forever. lol
CivicVTi
Post by CivicVTi »
Sorry, I meant load indeces. For example, right click on '-9%' and change the value to whatever you like (say 1%).
EGHATCH
Post by EGHATCH »
yeah i got what you mean,
but you can't edit the column value higher than the next column, you get an error message that says you cant go above the value of the next column. :(
it's weird, because some base programs, whenever i enable alpha n, the column values look fine, say, 5% - 105%
but most of the basemaps, when enabling alpha n, you get weird column values, like -9%, -9% to 5%. whats up with that
CivicVTi
Post by CivicVTi »
So start with the high load columns and edit them to an even higher value so you can go back to the low load ones and use the values you want.
hyro
Post by hyro »
i already discovered this! awesome !!
i run with itbs, and mapping with map pressure was very hard.
hyro
Post by hyro »
Hondata wrote:When using TPS based lookup the closed loop threshold is the calulated MAP from TPS, not the actual MAP.
so, the value you have to put in is tps % ?
hyro
Post by hyro »
can i use the boost tables to have more resolution?
CivicVTi
Post by CivicVTi »
I think you can. Haven't tried that though. But I think the extra resolution will just increase tuning hassle and time.
