wideband issue
Preccord00
wideband issue
Post by Preccord00 »
I've been tuning my fuel maps for the past month and I realized that when I tune the car at night it runs different than in the day, I took a closer look at my readings and found out that it's not that it's night or day, it's the power draw from my battery with my headlights.
Is there a way to make it so my headlights drawing off the battery dosn't adjust my AFR? it seems to run richer with the headlights on by about .2-.3 AFR.
What is the voltage at idle with the headlights off?
What is the voltage at idle wiht the headlights on?
Preccord00
which voltage? battery? ELD?
battery voltage
Preccord00
with nothing on, period, I get 14.00-14.05 V
with just the headlights on I get 13.85-13.90 V
I think you have found the problem. Your battery voltage should be pretty much the same with lights on or off. The voltage may drop for a second or 2, but will go right back to where it was.
Where are you getting you power and ground?
I recommend getting power from the ACC ON power source on the fuse box...this is a switched 12 volt power source. Any good solid chassis ground will work.
Preccord00
do you think it would be a good idea to buy a transistor voltage regulator tuned to 12VDC and put it in series with my current power source?
A voltage regulator should not make any difference, as the wideband will have internal regulation, but you could try it.
You could also try switching on electrical load (headlights + heated rear window + fan on full) and see if the AF ratio changes.
Preccord00
is electrical load going to work? I'm using the ELD line into the ECU for my AFR.
