What Ecu to use with rsx k20a3 engine with 6 speed tranny
jsimon9633
Post by jsimon9633 »
I have a dilemma i am trying to resolve
I have an engine from a 2002 rsx base automatic
I have a type s chassis that I will be putting this into
I am going to be using my type s 6 speed tranny along with the k20a3 engine from the base rsx
I want to make sure of a couple of things.
1. that i can use the k203 auto engine harness with this
2. What ECU would i need to run this? the BASE rsx 5 speed ECU?
3. is the gauge cluster and harness compatible with the base ecu either auto or 5 speed.
4. what would happen if i tried to run the base auto ecu with the 6 speed tranny?
thanks in advance!
the automatic harness will probably work, it's nto something we have a definite answer on. You will need a K-Pro for this, and since you are using a 6 speed transmission you should use a PRB ecu and have the wiring for the reverse lockout from the Type S engine harness.
jsimon9633
why would a base rsx 5 speed ecu not work?
imean i know it wont work optimally but why would it not work period?
You will not have reverse lockout.
jsimon9633
thanks
the thing is that this car will be used to daily drive only
my built k20a2 and my kpro i already have will be going into an EG
