making aem uego work with s300
fk83
Post by fk83 »
does any one know kow to set it up in computer
IT is exactly like the setup for the PLX wideband, but you cannot run the car in closed loop and use the wideband output at the same time using only one sensor.
fk83
Post by fk83 »
are the sensor voltages the same. can you run in close loop and data log tthe o2 thanks
No you cannot. The aEM has only one output. You must choose if you want narrowband or wideband output. IF you choose wideband output, you cannot use that sensor to run the car in closed loop. THis is why we recommend the PLX Devices widebnads, they have both narrowband an wideband at the sametime.
jordancivic
Post by jordancivic »
If you got an AEM and want to run closed loop, use the AEM to ELD input, and use a stock o2 sensor setup as well. ie 2 o2 sensors.
allanonjj
Post by allanonjj »
the voltage offset should be around -.4 . Just do a datalog and match your AF to the gauge.
