S300 CEL on
wagalude
S300 CEL on
Post by wagalude »
have a S300 and the CEL stays on all the time if i short the jumper it goes out
deafy
Post by deafy »
What is the error code? You may need to disable injector error if you have upgraded injectors.
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
wagalude
Post by wagalude »
running stock jdm h22 injectors 345's no codes when i jump out the cel plug light gose out when removed cel stays on
deafy
Post by deafy »
Post calibration
When you datalog are there error codes? Who socketed the ECU?
wagalude
Post by wagalude »
went out this morning and everything was fine don't know ghost in the machine i guess
