p06 ecu no vtec output
Tech3
Post by Tech3 »
first time we are using a p06 ecu for b16 engine. we have tried all the outputs for vtec activation. inverted or not. 2 outputs with no relays and 4 with relays. vtec doesnt work with the outputs with no relays. with the outputs that require relays we got the vtec activated but it turns off about 700rpms later and check engine light on dtc 21. we suspect a software glich. please help with this.
Can you post the calibration and a datalog? Is this using the alternate VTEC output? (if so, disable the VTEC spool error check).
Please also post the version of software you are using from Help, About.
scttydb411
Post by scttydb411 »
seems like it's just easier to convert the p06 to p28 and be done w/ it.
HONDATA DEALER/TUNING IN ATLANTA!!
DIGITALBOXTUNING
678-614-3596
If you simply post the version of software you are using, we may be able to determine why you are having the problem and it may as simple to fix as downloading the newest version of software.
Tech3
Post by Tech3 »
Spunkster wrote:If you simply post the version of software you are using, we may be able to determine why you are having the problem and it may as simple to fix as downloading the newest version of software.
version 1.2.3, dont have calibration and datalog onhand..
Current version is 1.2.6.0. Download the newest version.
Tech3
Post by Tech3 »
Spunkster wrote:Current version is 1.2.6.0. Download the newest version.
my bad. we actually were using the latest version 1.2.6.0. we disabled the vtec spool error check too.
Current version is 1.2.7.0
