Help on fuel trim
delsolb20
Help on fuel trim
Post by delsolb20 »
On the fuel trim is an injectors area that you can write your injectors
Stock injector size 290 cc/min - what does it mean if they are always going to be 290
Current injector size 440 cc/min
I want to know if on the low rev is going to run on 290 and on high rev is going to 440
Thanks!
[/img]
The stock and replacement injector size is used by the ECU to adjust the fuel table for injectors larger than stock. Low rev high rev?
delsolb20
Post by delsolb20 »
thanks for the support is working
