How much boost can you build on the S300?
thudreem
Post by thudreem »
How much boost are you guys building on the 2 step?
Also what settings are you running?
jew
Post by jew »
i build 10 psi with these settings
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
this is on a d16y8 with a turbonetics t3/t4 ball bearing turbo
thudreem
Post by thudreem »
jew wrote:i build 10 psi with these settings
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
DO you know if the spring in the wastegate and what you have the boost controller set at have a factor in how much boost you can build on the 2 step?
kesnut
Post by kesnut »
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
do you mind telling me what your timing is (in the map table) that your building boost in.
thudreem
Post by thudreem »
I played with the launch control and can now build 11 lbs with
limiter 7000rpms
activation 6000rpms
fuel 0
timing -10
turbotypeR
Post by turbotypeR »
mine makes abour 9psi at 7600rpm.fuel and timing are at 0
92 civic Si
best et:9.43best mph:164
thudreem
Post by thudreem »
turbotypeR wrote:mine makes abour 9psi at 7600rpm.fuel and timing are at 0
Does your car pop and crack, shoot flames out the exhaust when the launch control is on like shot guns going off?
jew
Post by jew »
yeah its supposed to do that cause you're dumping a bunch of fuel out the exhaust.
jew
Post by jew »
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
sorry it took so long to reply, i haven't been back to the site in a few days. i'll get a screenshot of my timing maps up for you tomorrow or friday.
no screenshots....post your calibrations and datalogs
Upperguy
Post by Upperguy »
any more info i have yet to use this feature i have msd 2 step now but would love to build good boost so i dont bog
turbotypeR
no it does not.once you start retarding the timing it will
92 civic Si
turbotypeR
no it does not.
92 civic Si
turbotypeR
no it does not.usually you don't see that until you start retarding the timing
92 civic Si
turbotypeR
92 civic Si
