any body using the mac valve for boost control
turbotypeR
Post by turbotypeR »
just was looking for someone using this solenoid to confirm that i am hooking up the wastegate lines right.i have the bottom port on the wastegate hooked to 1 and the pressure source, 2 hooked to the top wastegate port and 3 open to atmosphere.
92 civic Si
best et:9.43best mph:164
copy and past the folloing into an Internet explorer window and hit enter:
mk:@MSITStore:C:\Program%20Files\SManager\SManager.chm::/boostcontrollerinstallation.htm
turbotypeR
link didn't work
92 civic Si
IN Smanager, go to Help, contents and serach for boost control...read the boost control help topic.
turbotypeR
yeah,i have seen that.it is for the gm solenoid that i already have.i have changed to the mac valve,which is just like the aem normally closed valve
92 civic Si
Upperguy
Post by Upperguy »
how much was a mac valve compared to a AEM valve ?
turbotypeR
I have heard you can get them for $25. I bought mine from ebay for $60
92 civic Si
Upperguy
Post by Upperguy »
how is the valve working out ? is they way you had it hooked up correct ?
turbotypeR
The way I had it was correct. I haven't been able to use it yet though. I went the track, but only got 2 runs in. I tried 10% duty cycle on one run and 15% on the other. It only made wastegate boost. Later on, I found out that the solenoid doesn't do anything below 15% or above 90%. I haven't been able to get back to the track since.
92 civic Si
2 0 3
Post by 2 0 3 »
turbotypeR wrote:The way I had it was correct. I haven't been able to use it yet though. I went the track, but only got 2 runs in. I tried 10% duty cycle on one run and 15% on the other. It only made wastegate boost. Later on, I found out that the solenoid doesn't do anything below 15% or above 90%. I haven't been able to get back to the track since.
Hey, what is with the "dial knob" on the top of the mac valve ? AEM's valve doesnt have this?
And you mentioned wastegate side to 1, charge source side to 2...
Im confused by this...
Wouldnt a pressure line from the manifold have to "T" off one to one of the inlets on valve and other to bottom wastegate port ? Then the other valve outlet/inlet to the top of the gate ??
Can someone verify this ?
And to make it even more confusing... I have 2 gates..lol
turbotypeR
And to make it even more confusing... I have 2 gates..lol[/quote]
That is not a dial. It is just a piece of plastic. I assume has something to do with the way it is assembled. 1 has a "t" and goes to the pressure source(mine is to the compressor housing) and 2 goes to the top port on the wastegate. If you are using two gates, just "t" it off so both get the same signal.
92 civic Si
2 0 3
Post by 2 0 3 »
so when you say 1 has a tee and goes to pressure source...
do you mean from pressure source (comp housing) to the T, then from the T one line goes to wastegate bottom and other goes to MAC valve inlet #1
turbotypeR
Re: ??
2 0 3 wrote:so when you say 1 has a tee and goes to pressure source...
I'm sorry, I meant to say that 1 goes to the bottom wastegate port and the compressor housing and 2 goes to the top wastegate port.
I got it working last night. It worked much better than the GM solenoid. I had to use 50-55% duty cycle before it would do anything. I had to lower the solenoid activation to 10psi as well. I wound up with 50%=20psi,55%=30psi, 65%=32psi, and 70%=35psi.
92 civic Si
2 0 3
Post by 2 0 3 »
curious as to what spring is in your gate?
Your saying you didnt start to see an increase till 50% and @ 50% it was 20psi ... so is 20psi the min amount of boost you can run ?
Thanks, wirirng and plumping mine tonite
turbotypeR
2 0 3 wrote:curious as to what spring is in your gate?
I am using a .9 bar. It normally makes 15psi on the wastegate, but creeps to 20-25psi. So yes, 20-25psi is the minimum I can run right now. I think my creep is because I am outflowing my wastegate.
92 civic Si
