TPS Problems
Anointeddc5
TPS Problems
Post by Anointeddc5 »
I am having issues with my TPS. At idle it reads 0% but at WOT it only reads 98% what do I need to do to fix this?
First, the car will run fine if the TPS reads 98% at full throttle. It only needs to be over about 60%.
Second, you can adjust the TPS. Parameters->TPS->Scale TPS.
Anointeddc5
Thanks I got everything all figured out. My next question is how do you know if an injector or coil has gone bad? Will KPRO display the misfire code? Also what are symptoms of a fried ECU?
Are you having a problem? It's much easier to troubleshoot symptoms than to try to associate symptoms to a problem.
Anointeddc5
Well here is the thread I originally posted up http://www.hondata.net/forum/viewtopic.php?t=6150
The car just sputters (loses power) and stays at 6k rpm for about 5-10 secs then shoots past it but gets cut off completely at 7500 rpm. I have a tuner working on my a/f but even with all the changes we make the problem persists in the exact same spots, so I am wondering if it is a mechanical/electrical issue rather than a tuning issue although I know the calibration can be cleaned up quite a bit. I checked the wire harness and all seems fine except for the vtec solenoid looks a little on the melted side would that cause the problem?
Anointeddc5
Well the link I provided had the information you guys requested thats why I posted it up.
Engine setup:
RSX Type-S
k20a2
Greddy Turbo kit w/intercooler
IPS KT1 Cams
Eibach EVS with Ti Retainers
RC 750cc injectors
Walbro 255 Fuel Pump
Stock returnless fuel system
NGK Bkr8iex Plugs
Hondata KPRO ECU
Ground Cables
That was posted 4 months ago and you said you have had a tuner making changes to it.
