base rsx
vivalive
base rsx
Post by vivalive »
i just install kpro for my 05 rsx.
and i have 2 code. i'm wondering if i should worry about it?
what does those code mean? the tuner told me its fine i shouldn't worry about it... but i don't feel safe. i need you guys to help me out..
BTW at the moment i'm not running the primary 02 sensor.
Po112-IAT sensor low voltage
po661- Intake dual runner manifold low voltage
Thanks in advance.
:D
What vehicle , ecu and engine do you have?
vivalive
Post by vivalive »
Spunkster wrote:What vehicle , ecu and engine do you have?
05 base rsx/k20a3
ECU?
vivalive
Post by vivalive »
02-04 type-s ecu.with harness
You're using a base calibration in a type s ECU. The type s ECU will not drive the secondary intake runners. Your options are to disabled the secondary intake runners or switch to a base ECU.
vivalive
Post by vivalive »
Hondata wrote:You're using a base calibration in a type s ECU. The type s ECU will not drive the secondary intake runners. Your options are to disabled the secondary intake runners or switch to a base ECU.
how about the IAT sensor?
Do you get the IAT error with your stock ecu?
vivalive
Post by vivalive »
Spunkster wrote:Do you get the IAT error with your stock ecu?
i don't know...
but my tuner told me its normal, he called u Guys and said 05 will throw out that code.. :roll: so, that is why i'm wondering if i should worry about it. BY the way i don't have the 02-04 O2sensor, currently i'm just the 05 O2 sensor.
vivalive
Post by vivalive »
anyone??
chime in...
You should not receive any errors. You must follow the Helms manual for troubleshooting these errors and use process of elimination. Try your stock ecu.
vivalive
Post by vivalive »
if i were to use 05 primary O2 sensor
will it throw codes?
You cannot use the 05 sensor. You must use an 02-04 sensor.
vivalive
Post by vivalive »
Spunkster wrote:You cannot use the 05 sensor. You must use an 02-04 sensor.
i just change my IAT and my Primary o2 sensor.
but still get engine light for IAT Low voltage
and 1 more thing i also notice is my a.f graph is very wavey. i would shoot up to 32.x.1(isn't that to lean) and come back down to 14.7.1
i Uploaded k20a3 high octane map.
Please plug in your stock ecu and see if you continue to have the IAT error.
