no vtec
k20teggirl
no vtec
Post by k20teggirl »
Hi, I am new to this. I bought a modified car. Here's what happened..I was just driving home one day and the check engine light came on. So I downloaded K-pro, next day plugged it in and the car would turn over and die. So I changed some stuff like open loop and immobilizer. (after changing to a type-r w/ header map) The original was said to be an r-crew map. So it runs well but won't hit vtec, and it's throwing P1167, O2 heat sensor. And when I log it picks up a secondary but not primary O2 sensor. So not sure it the O2 sensor is bad, or bad wiring. Here's the info.
Serial # 37820-PRB-305
1998 integra with a K20 (type r)
It has an r-crew header and PIMP and a jank intake.
I don't think I have a datalog saved, if need be i can do one and add later.
Any suggestions please, this is really irritating me!
The first attachment is the one that was on the car when I got it, that now runs poorly. The second attachment is the one I am using now that won't hit vtec but otherwise runs well.
1998 Integra K20 JDM front
2000 Prelude, type-SH (for sale)
1994 Accord 220k
You'll need to find out what error code you have by datalogging.
Also read http://www.hondata.com/techk20swaps.html
k20teggirl
I know it's P0131, O2 low voltage because I have datalogged, I just don't have one saved. Do the maps look good, or any suggestions on those?
1994 Accord 220k
A bad o2 sensor doesn't usually throw a code, so I'd guess wiring issues.
k20teggirl
Do the maps look good? I'm new to this so any suggestions would be helpful.
1994 Accord 220k
k20teggirl
help please, anybody have suggestions or can check out the maps to see if that's the problem. Cuz the original did run great.
1994 Accord 220k
