Using boost table for NA;Spunkster/Hondata
planetspeed
Post by planetspeed »
Hi! could I use the boost table for NA?I'm planning to use all the 13 columns and just edit the load index's to max out at 103kpa at column 13..The additional columns would narrow down the load index per column allowing a more precise tune..
Yes, that will work. We normally do this for ITBs.
planetspeed
Thank you very much, Hondata! I appreciate your reply.
