motorola 2.5 bar map sensor
alexsracing
Post by alexsracing »
I go to parameters > map > quick select > motorola 2.5bar
how do I get the table to show the new scale??
I see where to show 3 bar and 5 bar tables but no 2.5
2001 Acura Cl
1994 Civic CX SFWD in the works
Select 3 bar and you will get 16 columns up to 28 lbs. The last column is not used with the 2.5 bar sensor (which reads to 22 lbs).
alexsracing
ok
2001 Acura Cl
Teamko
Post by Teamko »
following this same issue. I need a 3 or 4 bar map sensor and have a motorola also Hondata doesn't have settings for 3 or 4 or 5 bar motorola. I have the data sheet but don't see a direct corrolation to input into the scalar value and offset Hondata requires to make the map sensor work correct any assistance?
Refer to the KManager help file on how to calculate the scalar and offset.
Teamko: First & final warning: Stop commercial spam or be banned.
