06 SI
Questions / support for the K-Series ECU re-flash
htec17
06 SI
Post by htec17 »
I would like to know if the tsx throttle body can be used with the 06 SI with the comptech charger? and can I run the tsx bottom end with the reflash I have for it now?
2020 civic si,flash pro,afe intake,afe exhaust,prl intercooler,acuity short shift and eibach springs
I don't know about the throttle body, but changing to a 2.4 block will not be compatible.
htec17
Post by htec17 »
would you use the hondata img or the comptech one supplied with the charger?
It is completely up to you.
htec17
Post by htec17 »
Would it be worth using the 05-06 rsx type s cams being they are the type r cams and the stock ex cam on the si is the same as the 04 type s ex cam? how much of a diffrence will i get with the 64mm throttle body.
