2 0 3
Posts: 23 Joined: Sun May 20, 2007 9:49 am
Post
by 2 0 3 » Sun Oct 14, 2007 7:05 pm
with engine off, can datalog
engine running wont datalog at all.
we were using a non resistor plug, but today switched to a iridium resistor plug. I was hoping this would fix the dataloging problem. It didnt.
Would the location of our ignition box be affecting dataloging??
The M&W pro10 is mounted about 1 ft away from the ECU.
Will this cause the s300 to not datalog??
Posts: 24345 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Oct 15, 2007 9:58 am
Use of aftermarket ignitions can cause tremendous amounts of intereference and will cause you to have dataloggin issues. The stock ignition system should be capable of the power you are making.
2 0 3
Post
by 2 0 3 » Mon Oct 15, 2007 1:46 pm
it made 560whp at low boost. i don't think stock ignition will do much for us at full boost.
meh. ill figure it out.
Posts: 10665 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Mon Oct 15, 2007 4:01 pm
Using non-resistor plugs can permanently damage the ECU.
If using an MSD then use the stock ignition wires, the stock distributor cap with the built in resistor on top of the rotor, and resistor plugs.
Post
by 2 0 3 » Mon Oct 15, 2007 8:30 pm
Ill try to throw this ecu into a buddys car and see if its datalogs to verify if the ecu is damaged.
as far as the ignition right now.. M&W pro 10 box. NGK blue plug wires & resistor plugs. MSD cap with external crane PS92 coil. stock oem GSR rotor.
2 0 3
Post
by 2 0 3 » Tue Oct 16, 2007 9:27 pm
Moved the M&W out into the engine bay, made sure to use shielded wire everywhere possible...
Can now datalog perfectly fine :D
So for us guys with aftermarket ignition boxes... just be sure to mount them far away from the ecu
Hope this helps/helped some people.
crucian
Posts: 199 Joined: Sat Dec 10, 2005 9:42 am
Post
by crucian » Thu Oct 18, 2007 11:08 am
Good looking out! :D
