tryfe
Posts: 25 Joined: Sat May 14, 2005 5:16 am
Post
by tryfe » Sun Oct 21, 2007 6:03 am
I'm only thinking of this because the other day my fiance flogged my car as soon as she fired it up & backed out of the driveway..
How about implementing an alternate Rev Limiter when the engine is still cold? For example, be able to set the Rev Limiter to 4k when the ECT is below normal operation temperature...say below 180 degrees. Can this be done?
petah
Posts: 32 Joined: Sun Nov 13, 2005 7:48 pm
Post
by petah » Sun Oct 21, 2007 3:14 pm
better way to protect your car is dump your fiance and find a girl that will treat your car the way you would.
tryfe
Post
by tryfe » Sun Oct 21, 2007 3:30 pm
petah wrote: better way to protect your car is dump your fiance and find a girl that will treat your car the way you would.
No.
Posts: 24338 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Oct 22, 2007 10:31 am
Prameters, Protection. Set it to 5 inches of vacuum.
tnhatch02
Posts: 30 Joined: Mon Feb 12, 2007 3:42 pm
Post
by tnhatch02 » Mon Oct 22, 2007 11:07 am
lmao. all you should have to do and say is be careful. that or never let her drive ur car again.
tryfe
Post
by tryfe » Tue Oct 23, 2007 2:42 am
Spunkster wrote: Prameters, Protection. Set it to 5 inches of vacuum.
Thank you.
JJA12
Posts: 1 Joined: Thu May 10, 2007 12:35 pm
Post
by JJA12 » Tue Oct 23, 2007 11:31 am
By doing so, what will be the limited rpm?
petah
Post
by petah » Tue Oct 23, 2007 11:50 am
JJA12 wrote: Spunkster wrote: Prameters, Protection. Set it to 5 inches of vacuum.
until the coolant temp is over the specified limit
tryfe
Post
by tryfe » Sat Nov 10, 2007 8:43 am
I've observed that my car will not go WOT; which is exactly what I wanted until the car warmed up.
