Cold Engine Rev Limiter?
tryfe
Post by tryfe »
I'm only thinking of this because the other day my fiance flogged my car as soon as she fired it up & backed out of the driveway..
How about implementing an alternate Rev Limiter when the engine is still cold? For example, be able to set the Rev Limiter to 4k when the ECT is below normal operation temperature...say below 180 degrees. Can this be done?
petah
Post by petah »
better way to protect your car is dump your fiance and find a girl that will treat your car the way you would.
tryfe
Post by tryfe »
petah wrote:better way to protect your car is dump your fiance and find a girl that will treat your car the way you would.
No.
Prameters, Protection. Set it to 5 inches of vacuum.
tnhatch02
Post by tnhatch02 »
lmao. all you should have to do and say is be careful. that or never let her drive ur car again.
tryfe
Post by tryfe »
Spunkster wrote:Prameters, Protection. Set it to 5 inches of vacuum.
Thank you.
JJA12
Post by JJA12 »
By doing so, what will be the limited rpm?
petah
Post by petah »
until the coolant temp is over the specified limit
tryfe
Post by tryfe »
I've observed that my car will not go WOT; which is exactly what I wanted until the car warmed up.
