japerformance
Posts: 25 Joined: Sat May 20, 2006 4:24 am
Post
by japerformance » Sun Nov 18, 2007 7:59 am
Hello Peeps,
having a small problem. i have a EK9 fitted with the s200 the cel light is on all the time, i have replaced the ecu with a p28 , i have changed out the s200 with my own dealer one i have changed the roms etc nothing seems to cure the cel. in hondalogger no error codes are coming up any ideas , has anyone had this happen to them before.
regards
Posts: 24345 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Nov 19, 2007 10:49 am
Do you have the knock sensor disabled? Have you tried datalogging to see what the error code says?
japerformance
Post
by japerformance » Mon Nov 19, 2007 6:02 pm
yes have disabled the knock sensor and have also ran hondalogger with no error codes showing am stumped
ek9lee
Posts: 4 Joined: Tue Nov 20, 2007 5:57 am
Post
by ek9lee » Tue Nov 20, 2007 5:59 am
Hello Simon I just registered here to see if I could find out anything but it seems your 1 step ahead of me :lol:
Post
by Spunkster » Tue Nov 20, 2007 3:10 pm
Is the light on the interface box flashing or solid? Based on the fact that you have changed everything ecu and Hondata related and the problem still exists, it sounds like a wiring problem or problem with the cluster. Does the light go out at all or is it on whenever the key is on?
ek9lee
Post
by ek9lee » Tue Nov 20, 2007 7:39 pm
The light on the interface box is solid. The light goes out when the ignition is at number 2 then its constant when car is started and running.
Post
by Spunkster » Wed Nov 21, 2007 10:34 am
I'm asking about the Check engine light on the cluster
ek9lee
Post
by ek9lee » Wed Nov 21, 2007 8:25 pm
Yeah sorry thats what I was on about in the second sentence of that post.
ITR 1102
Posts: 144 Joined: Sun Sep 10, 2006 9:52 am
Post
by ITR 1102 » Fri Nov 23, 2007 8:51 pm
I had a similar issue once... Turned out that the chip was not burned correctly. Do you get the same results when using the ostrich?
Post
by Spunkster » Tue Dec 04, 2007 10:36 am
Datalog and check to see what you have the shiftlight set to.
ek9lee
Post
by ek9lee » Fri Jan 04, 2008 1:32 am
The shift light wasn't installed
Post
by Spunkster » Fri Jan 04, 2008 11:05 am
not having a separate shiftlight installed has nothing to do with checking the settings I have suggested. Please check to see what you have the shiftlight set to. If it has been set below what your car idles at, the CEL will always be illuminated.
marlborocars
Posts: 16 Joined: Mon Aug 22, 2005 4:33 pm
Post
by marlborocars » Fri Jan 04, 2008 4:45 pm
Just tap a wire between D6 and A4. The B16B don't have the vtec pressure switch.
mike93hatch
Posts: 64 Joined: Wed Dec 12, 2007 9:48 pm
Post
by mike93hatch » Fri Jan 04, 2008 5:19 pm
marlborocars wrote: Just tap a wire between D6 and A4. The B16B don't have the vtec pressure switch.
why would you do that when you can just disable by checking a box in hondata?
