JDM H22 ECU
xmasterx87
JDM H22 ECU
Post by xmasterx87 »
Hey, quick question. i have a 95 accord EX with a JDM h22 engine/ecu combo. do i need to change my ECU for the s300J to work or can i use the one i have??
ITR 1102
Post by ITR 1102 »
To my knowledge, P13's are not supported. I may be wrong on that, so you can wait for another reply... But, I don't know of anyone with a chipped P13 (H22 ecu)
xmasterx87
Yea... i need to know cause i want to be able to tune it myself... but i need to know if it works... if in the case that it doesnt, is there another ECU that i could just plug and play with??
ITR 1102
Post by ITR 1102 »
xmasterx87 wrote:Yea... i need to know cause i want to be able to tune it myself... but i need to know if it works... if in the case that it doesnt, is there another ECU that i could just plug and play with??
An H22 motor will need a P72 or similar ecu that can control the IAB's in the intake manifold. If IAB's have been removed or you are running a Skunk 2 intake manifold, you can use a P28 ecu.
xmasterx87
well right now its stock but i plan on getting the skunk2 intake mani and the throttle body... do you think the p28 would work with the stock mani for now?? and would it be a plug and play kind of thing or do i have to switch wires at all considering its a JDM engine??
If you are planning the swap manifolds, then a P28 will work fine for you. A P13 cannot be used.
LikWidChz
Post by LikWidChz »
Crap, I have a P13 and for some reason I assumed you could use it cause i thought it was supported by hondata sheesh was I wrong,
Either way not to take over here, you guys have any info on weather or not I should wire up iab's or not?
right now mine are just not connected to the vac line and simply stay open.
Give me a screw driver and ill take it apart.
