D10 ELD
DOHCAccord
Post by DOHCAccord »
mike93hatch you cut em both and it now is a dead on match from your laptop to the actual reading of the wideband?
Plus what ecu are you using if i may ask, p28, etc.
mike93hatch
Post by mike93hatch »
DOHCAccord wrote:mike93hatch you cut em both and it now is a dead on match from your laptop to the actual reading of the wideband?
that is correct... running a p28
OTT
Post by OTT »
heres a good Question then... do HONDATA remove these two resisters from their HONDATA prepared ECUs ???? :idea: :?:
mike93hatch
OTT wrote:heres a good Question then... do HONDATA remove these two resisters from their HONDATA prepared ECUs ???? :idea: :?:
i would probably say no..
These are not removed on any Hondata prepared ECUs.
OTT
Post by OTT »
in this case I have a different related question...
when D10 ELD is being used for wide-band input and ELD is disabled....
1. will removing the two resistors affect normal operation of the ECU?
2. Do I need to install a jumper to replace each resistor or can I simply cut the resitor out?
You only have to cut them. It will not cause any problems.
Teamdiesel
Post by Teamdiesel »
besides D10, what other methods can be used to connect the white wire of an AEM wideband to incoorporate it with the hondata s300?
2000' JDM CTR, 12.704 @106.38mph w/1.7 60ft
laziebun
Post by laziebun »
i just pop mine out and we'll see how it goes..................to be continue
laziebun
Post by laziebun »
well im piss this damn thing...................well i took off the r136 and r138 and now my AFR is just showing 2.00 what the hell is going on someone help me!!!!!!!!!!!!!
OTT
Post by OTT »
laziebun wrote:well im piss this damn thing...................well i took off the r136 and r138 and now my AFR is just showing 2.00 what the hell is going on someone help me!!!!!!!!!!!!!
Free bump! I want to know whats happened!!? your got this sorted now??
Teamdiesel
me too, what happened?
planetspeed
Post by planetspeed »
Hope you had cut the correct resistors on the exact location..coz I had cut mine and the AF values are dead on with the gauge and laptop.
hondapowaa
Post by hondapowaa »
Jdm ecus have the d10/eld active.
But no one can tel me what resistor i must remove.
If i connect wideband directly i have a bad reading, impossible to down under 1/1,5v
So i connect on the d14 but i really want to know what are the resistors we must remove on the JDM ecu to work :)
scuse for my bad english, i'm not english :p lol
There are no resistors that need to be removed on a JDM ecu.
