External wideband O2 - Display
Maverik
Post by Maverik »
Hi,
I own Euro Civic Type R (PRA ECU) and for tuning I'm using an external wideband O2 sensor (TechEdge) connected to the ELD pin. Everything works fine and I take the ELD.V (volts) as a reference for the external O2 sensor AFR. Is it possible to display the ELD.V directly converted to AFR?
Go to Options, Settings, and on the Wideband Input tab you can select the input and calibration information to use.
