Onboard Datalogging Start/Stop using Manual Switch
trlaing
Post by trlaing »
How do the Onboard Datalogging manual switches work?
Is there some way to just switch it on and off when I want?
I notice that there is the E16 Power Steering pressure switch. Is that on when steering to the limit to one side?
How do I know if Onboard Datalogging is switched on?
You must cut the wire that goes to it's original location and connect your own switch to it.
trlaing
Post by trlaing »
Ah....I'll just stick with the laptop then!
Cheers
