boost control issues
Lazysk8r2
Post by Lazysk8r2 »
I have the GM boost solenoid 1 wire connected to the battery for the power and the other wire connected to A11 i think.
I have the Boost control enabled and normally open clicked and fixed duty cycle set to 0%. Its not hitting 7 pounds like in the wastegate spring. Its keeps on hitting boost cut set to 10. I am trying to get it to what the spring is set for. What am i doing wrong?
What happens when you just disable boost control?
Lazysk8r2
Post by Lazysk8r2 »
it goes past and spring pound and hits the boost cut set to 10. iv pulled the vac line off also and it went to 7 which is the spring
A normally open solenoid cannot be disabled or set too low. Since it is normally open, activating the solenoid is actually closing the flow of air off..try setting it to 15% and then 25% and see what it does.
verlee24
Post by verlee24 »
i have the same exact problem. boost cut set at 10, boost set for 7, spring is 7psi. but it always goes to boost cut. got any other ideas? i tried normally open at 25% 15% and 5%
Td16z6
