Boost Control Components
snwbrdrx19
Post by snwbrdrx19 »
Does anyone have the specs on the components needed for boost control. The manual shows a large and small transistor, diode and 2 resistors (330ohm and 220 ohm) what transistors and diode are needed.
We sell the boost components as an install kit, but do not provide information of the exact component specs.
The reason for this is that if we did, then we'd end up fielding many support calls on what components to get / where to buy them / the right way to solder them / troubleshooting bad installs etc. This almost certainly would be a false economy for both ourselves and the customer.
With a base knowledge of electronics the components are very easy to identify and purchase, but we're not going to list them here for the reasons outlined above.
