S2000 Kpro Ignition
JustinC
S2000 Kpro Ignition
Post by JustinC »
Curious as to why the ignition is set to 30deg in the tables but when you do the datalog it reports 25 deg of ignition. Is there a reason it wouldn't follow the tables ?
2005 S2000
Kpro serial number 4923
Where exactly in the datalog are you referring to this (time stamp)?
JustinC
Post by JustinC »
An example would be around 2:40 at the top of the run...ignition values in the table show 30s and the ignition on the sensors is 25
or around 2:37 at about 5660 rpms the ignition values in the table are around 30 and the ignition value is 17deg
Air temperature retard. 138 degrees sounds high for air temperatures. What IAT sensor are you using?
JustinC
Post by JustinC »
Hondata wrote:Air temperature retard. 138 degrees sounds high for air temperatures. What IAT sensor are you using?
I am using the one you recommended on the S2000 Page
P/N 37880-P05-A00
This is the same IAT I made a different thread for saying that I thought it was not reporting the correct IATs.
http://hondata.net/forum/viewtopic.php? ... highlight=
JustinC
Post by JustinC »
hello...is this thing on...any input would be appreciated...was the temperature retard a statment or a suggestion
We are still looking into this. It is not a problem with the temp sensor you are using.
As soon as we have more details we will let you know.
JustinC
Post by JustinC »
Spunkster wrote:We are still looking into this. It is not a problem with the temp sensor you are using.
Okay, thanks for the update.
The retard is generated when the IAT is over about 100 degrees F, only when VTC is disabled.
Try this calibration (it is your calibration modified to remove the IAT based retard).
We'll add this table to the next release of KManager.
JustinC
Post by JustinC »
I will try this calibration.
Could one of you two please clarify why this new IAT reads so high. You say it is the proper resistance for the KPRO Ecu but it reads above 100deg even when ambient temperatures are around 70deg. Have you logged the normal IATs on a stock S2000 and then swapped it over and monitored the IATs with this sensor and KPRO ?
I know it is placed in the Intake Manifold instead of the intake piping so is it typical for the IATs to be so high ?
Garrett_si
Post by Garrett_si »
I add about the same issue saturday on the dyno
the IAT sensor recommend read high temp (110-120 on each run)
I installed a fan directly on the Intake manifold, and everything was fine after that
