Pretty N00bish Problem...
brandn3w
Post by brandn3w »
So I'm new to K-Pro and all but not the Honda scene. I've looked through the stickies, searched, and read through the Help section on KManager itself.
I'm still having a problem "reading" the ecu. See I just got the car and I wanted to see what the values were already set at and go from there rather than upload a new program. I get as far as going "online" then I click the display to see if it's reading anything then I revved it to see any change then it went off line again.
Long story short, I can't get KManager to stay "online" when the car is running so that I can read the values and parameters of the current map on the car. :D
2003 RSX Type-S
Thank you!
The car should not be running when trying to read a calibration out of an ecu. You should just have the key in the on position. Beyond that you will have to be specific in exactly what you are clicking on and doing.
You may be confusing datalogging with reading the ecu.
brandn3w
Post by brandn3w »
Spunkster wrote:The car should not be running when trying to read a calibration out of an ecu. You should just have the key in the on position. Beyond that you will have to be specific in exactly what you are clicking on and doing.
Nah, I know the difference just thought that the car needed to on to read the parameters and what not. I thought I read somewhere though that K-Pro doesn't allow you to read the the ecu on update a calibration and alter that, NOT check/read what is on it already.
