Kpro with 06 RSX wiring Harness, 06 CivicSI tranny,06 K24A2?
Gage
Post by Gage »
I'm wondering if I can make this combination work in a kit car, NOT a Honda Body.
A Civic SI Manual transmission with LSD, 06 TSX Engine, and 06 Wiring Harnesses with the Kpro.
Can any experts offer an definite answer?
It was initially suggested to me to use an RSX S transmission with this combo, but it lacks the LSD.
You should use an 02-04 harness, and transmission. You can use the guts of the transmission you have with the 02-04 case and adding a ring gear to the final drive.
Gage
Post by Gage »
Thank you sir.
Garrett_si
Post by Garrett_si »
The simpliest way for you is using the RSX S 05-06 K-pro with adapter harness
the 05-06 k-pro use the countershaft speed sensor, so you will not have to change the tranny or the cassing
You should not use the 05-06 KPro with an engine swap unless the engine swap wiring uses the correct 05-06 E connector wiring. To the best of our knowledge no engine swap wiring kits that you can buy do this, so most people just plug the E connector into the 02-04 ECU, which is something we specifically prohibit.
