Launch control
cukali
Launch control
Post by cukali »
2005 Si K-pro K24A1 swap with turbo.
I did a software update a feww weeks ago change a few settings on my car. After that my launch control has not worked. Rev limit seams to be fine. All other functions seam to be working fine also. Any ideas?
I have it set to 4500 but it revs right past. I check and uncheck several times, restarting, and rebooting, nothing seams to get it working.
thnx in advance.
carbonctr
Post by carbonctr »
Which version of KManager are you using? 1.2.3.5 has a problem with launch control activation settings. Updating to 1.2.3.8 should sort it....
cukali
Post by cukali »
Latest version.
saying latest version means nothing. What is the version number from Help, About?
cukali
Post by cukali »
1.2.8
I see its been changed and I am not the only one a little confused, can you tell me what selections to chose to have my launch control set to 4500 again? I tried "always on/off" but I see thats not the correct one.
Also, can you give an estimate of how much retard/fuel addition for a good start on the shift option? I find it a good upgrade and will be using it.
thnx
In Kmanager, go to Help, Contents and search for "launch control" and read the details of how it works.
Conquistadore
Post by Conquistadore »
cukali wrote: ...can you tell me what selections to chose to have my launch control set to 4500 again? I tried "always on/off" but I see thats not the correct one.
Here is how I get that working...
2002 Euro Civic Type R
KPro (SN:05506, HW Ver.:2.16, FW Ver.:2.02)
Hondata Heat Shield Gasket
BDL 66mm Throttle Body
Fujita F5 Cold Air Intake
Toda Headers
Mugen Power Mid Pipe and Twin Loop Rear Silencer
AEM UEGO 30-4100 Wideband Controller
